Ground clamp
发表于 2021-8-31 22:27:25 | 显示全部楼层 |阅读模式
I bought a new ground clamp. I didn't realize how much bigger it was until I put them side by side. Tweco claims 500 amps. Which Is over double what I need but she clamps really strong. Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Yeah and half the price of the brass ones. Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Originally Posted by Austin BennettYeah and half the price of the brass ones. Sent from my iPhone using Tapatalk
Reply:I'm far from a collection the old one (on the right) is to replace the cheapo HF clamp on my 80a inverter I broke it last week by looking at it wrong. Mine cost just under 25 but that's airgas for ya Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:I wasn't sure if you were being serious or a sarcastic a-hole. So I checked and you really do have a torch collection. so if you want to add to it here's a smith #5 in need of a owner to give her some tlc. Interested?Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Sorry it's a mw5 handle Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:When I was making the leads for my Ranger 305G I ordered the same clamp and a 300a stinger from Tweco, Very pleased with both products...Hobart Stickmate LX235AC/160DCRanger 305GVictor 315 O/A rigHope to acquire in the next couple of years: Hypertherm PM45 and Dynasty 200DX
Reply:Originally Posted by Austin BennettI wasn't sure if you were being serious or a sarcastic a-hole. So I checked and you really do have a torch collection. so if you want to add to it here's a smith #5 in need of a owner to give her some tlc. Interested?Sent from my iPhone using Tapatalk
Reply:You should try this one. Its friggin awesome. It the Stronghand Ground Hog Attached Images
Reply:Originally Posted by sbchp355You should try this one. Its friggin awesome. It the Stronghand Ground Hog
Reply:I have used several ground clamps through the years and the all get hot unless you maintain the cleanlinessof the connection.....running 275 amps AC all day heats things up and makes smoke happen from the ground lead.....I ended up crimping an eyelet on the end of my ground cable and bolted it to the table with a 1/2 bolt.....Even after two hours of constant welding its cool as a cucumber....Using a milling machine vice I clamp my parts or a larger weld fixture.....   Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:my ground on the 110v mig was getting hot so i switched to this. it works much better. Attached Imagesi.u.o.e. # 15queens, ny and sunny fla
Reply:The point where the finely stranded cable enters the clamp is a problem. Make a fresh connection, it isn't long before it frays. Tin the stripped lead, slip on a heat shrink tube with sealant over the cable, coat with Noalox, and make connection. Slide over the heat shrink and heat it with a heat gun. You'll get longer from a connection, then all you need to worry about is A holes with fork lifts.
GMT+8, 2026-1-1 01:56 , Processed in 0.095080 second(s), 18 queries .
