I hate those "Oh Duh" moments
发表于 2021-8-31 22:27:25 | 显示全部楼层 |阅读模式
So I'm building a mobile base for my table saw and decided I was going to do it all Tig.  Its mostly 1 1/2 x 1 1/2 x 1/8 angle and some 1/8 plate. Things are going along great, got the frame all fitted and welded up, welds are starting to look consistent if not passable.  Last night I built the housings for the rear wheels (it will have fixed wheels in the back and full locking swivel casters on the front), it was getting late but I wanted to get them mounted because I knew I probably wouldn't be back to this project till after Memorial Weekend.  As I'm welding them on my welds go to crap, sometimes even having a hard time starting an arc, the welds are porous and I'm having to really lay down the amps to get any penetration.  The whole time I'm thinking what the h$ll, is the welder dying, did I use the wrong grinder and contaminate my tungstens, am I running out of Argon?Well, it finally hit me at work today what happened. I was in such a rush to "finish" I didn't prep the frame so I was trying to tig through the millscale....doh!!
Reply:That's what 6010 is for.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:If that's your best "Oh Duh" moment, you're a genius compared to me.  I can go on for a while here....Using a piece of 3/32 SS filler as my tungsten...Ground cable across my lap and not connected and the HF taking the shortest course...Leaving a piece of wire in my mig liner and not understanding why wire won't feed....The list goes on and on.
Reply:I'm in the bad habit of holding the tig filler rod in my mouth between welds when I need my left hand to set up the next part.   Seems like about once every 6 months or so I'll get the hot end to close to my lip and burn it.
Reply:went to reposition while tig welding and stuck the hot end of the filler right through the crotch of my jeans, fortunately I stopped before it got to the important bits.
Reply:I'm not the only one then! Or you have a long piece and you try to flip down your helmet. Chattered my teeth hard a few time doing that.  Originally Posted by 4956I'm in the bad habit of holding the tig filler rod in my mouth between welds when I need my left hand to set up the next part.   Seems like about once every 6 months or so I'll get the hot end to close to my lip and burn it.
Reply:Frozen nut on a 5/8 bolt. Bolt in the vise, heated the nut red and spun it off with a wrench. Shut off the torch, shucked the gloves, grabbed the bolt barehanded. Cooked the threads right in thumb and finger. Boss lady thought the threads felt "unique". I am so a dumbarse.                                                         ChuckTo ride, shoot straight, and speak the truth. This was the ancient law of youth. Old times are past, old days are done, but the law runs true oh little son.Winpower 180 DCSA-200 redfaceXMT-304
Reply:Rookie no one has ever done that before.....Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:The other day I used some 308 stainless rod to weld some 6061 Aluminum... Couldn't for the life of me figure out why the rod wasn't taking to the puddle.... oh yeah I thought this rod felt a little too heavy...Last edited by TTnicksocal; 05-14-2014 at 07:27 PM.
Reply:somehow jammed tig fill hot end into my sternum once. . . ouch.many others but one of my favs was pulling a last bit of hard-wire out of a mig-gun, prolly had 10' coiled in my hand, and grounded, and bumped the trigger. . . . god I hate that smellbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
GMT+8, 2026-1-1 01:56 , Processed in 0.096778 second(s), 18 queries .
