My $10 diamond wheel tungsten grinder
发表于 2021-8-31 22:27:24 | 显示全部楼层 |阅读模式
[ame]http://www.youtube.com/watch?v=bH9h5Tu76As[/ame]This works way better than using a grinding wheel!  No more grooves and crap flying everywhere.  Thought some of you might find this useful.JonMiller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:What is your grinder RPMS ???  If this is the wheel from hf it is max out at 6600 rpm.http://www.harborfreight.com/replace...ner-98862.html
Reply:Originally Posted by BD1What is your grinder RPMS ???  If this is the wheel from hf it is max out at 6600 rpm.http://www.harborfreight.com/replace...ner-98862.html
Reply:Jon, have you tried it without the drill? I recently got a diamond wheel for one of my bench grinders, and with one slow twist from a blunt end they come out like a smoothe razor tip in half the time with less effort. And for the most part all I use is 3/32. Give it a shot. here's a pic of one done in a few seconds. Attached ImagesI hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Here's the set up iv'e been using. Amazing differance the diamond wheels make. No sparks no noise and in 2 seconds your done, and with no grooves   Attached ImagesI hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Awesome wheel. That's what I use, but I use it with the grinder it was made for:http://www.harborfreight.com/120-vol...ner-96687.htmlI removed all of the guards, handles, and fixed it so it doesn't move. So I ended up with this:kidtigger24 Attached Images  They think I’m crazy, but I know better. It is not I who am crazy. It is I who am MAD!
Reply:^^ Thats cool!Miller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:Originally Posted by Jon K^^ Thats cool!
Reply:i use the 5 inch HF Grinder with that diamond wheel with this arbor adapter that i machinedsmall and portable Attached ImagesLast edited by WeldorWes; 03-10-2013 at 01:53 PM.Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Jon K you could do a voice over for Dane Cook, seriously... I like the tungsten grinder.... I too have a H/F bench grinder I was going to install one of those diamond wheels but didn't know which one...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:DUH !  I guess I wasn't awake yet.   Grinder, first thought was hand held 4'' and not a bench. . I  like that HF setup, great idea . Sale price is 50.00 and with 20 % coupon drops down to 40.00 plus you get two wheels with it.Last edited by BD1; 03-10-2013 at 04:06 PM.
Reply:Originally Posted by weldermikeHere's the set up iv'e been using. Amazing differance the diamond wheels make. No sparks no noise and in 2 seconds your done, and with no grooves
Reply:I use a cheap 6" HFT bench grinder with aluminum diamond-grit cabbing wheels off ebay. The left-hand wheel is the one that comes with the HFT grinder (I find that if you keep moving the tungsten around on the wheel, you won't get grooves in the wheel; you can also grind the tungsten at 90° to this wheel, since you will remove the grinding marks when you go to the diamond wheels) and on the right-hand side of the grinder are two aluminum cabbing wheels (bought from rocklady on ebay) in two different grits. I got this idea from SundownIII here. Works great.
Reply:To the OP. Youtube police got to you as your video is blocked because of some music content. I would like to see your set up though or another video. I do know this post is a year old as well.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Originally Posted by TJSTo the OP. Youtube police got to you as your video is blocked because of some music content. I would like to see your set up though or another video. I do know this post is a year old as well.
Reply:Yes I have a lathe. The original vid is still there, however it is in fact blocked by YT because of music content. Thanks.T.J.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:So the real question is: who is going to mass produce that spacer.  I don't have a lathe (yet). 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Originally Posted by OscarSo the real question is: who is going to mass produce that spacer.  I don't have a lathe (yet).
Reply:I have been producing the spacers for this mod for awhile nowSent from my iPhone using TapatalkMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Send me a drawing if you want, am always lookng for random tasks to keep up on my lathe skills
GMT+8, 2026-1-1 01:56 , Processed in 0.072356 second(s), 18 queries .
