starter and other parts
发表于 2021-8-31 22:27:18 | 显示全部楼层 |阅读模式
Im looking for a starter,points and carb kit for a 71 sa 200. I figured that napa might carry them but not sure. thanks
Reply:Greetings, Danny LillyWith Continental engine, the high mount starter should be this one: Delco - 1107382 NAPA - RAY440448 http://www.napaonline.com/masterpage...emfd+-+PremiumGood Luck
Reply:The 1107382 is the shaved side, low mount starter, but that is the one that should fit a '71 unless somebody changed something. We have those in stock as well as the high mount unit and can get you that number if you need it. weldersales
Reply:AWSOME! thats what I have been looking for. Thank you very much.
Reply:What about points and carb kit? Can you get them at napa as well?
Reply:Originally Posted by Danny LillyWhat about points and carb kit? Can you get them at napa as well?
Reply:Mag is FMX4B16A, carb is Marvel TSX979, most likely. Denrep, that starter is the first part we searched for 35 years ago. 1107382 is burned into my memory better than social security number or drivers license number. weldersales
Reply:If you had to guess, what would those parts cost?
GMT+8, 2026-1-1 01:56 , Processed in 0.075352 second(s), 18 queries .
