newbie question
发表于 2021-8-31 22:27:17 | 显示全部楼层 |阅读模式
I am looking to buy a mig welder. I have done some welding in my past. I will mainly use for doing some work on my truck things like maybe reinforcing the frame where the gear box is,making battery boxes things like that frame work would be the thickest I would be welding.My question is I have been looking at lincoln 3200weld pak or theweld pak 175hd both from home depot any bad things about these 2? I would like to hear from you guys before I make the decison not looking tospend more than$650.00 also maybe would weld some aluim.   Thanks in advance
Reply:this was a thread started latley about small starter welders. reading it over might help a little.http://weldingweb.com/vbb/showthread.php...hlight=110+mighttp://www.aloumac.ca/
Reply:Buy the 175, buy the 175, buy the 175,.... weld it like you own it
Reply:thats true, you wont regret having MORE power.http://www.aloumac.ca/
Reply:Originally Posted by 915I am looking to buy a mig welder. I have done some welding in my past. I will mainly use for doing some work on my truck things like maybe reinforcing the frame where the gear box is,making battery boxes things like that frame work would be the thickest I would be welding.My question is I have been looking at lincoln 3200weld pak or theweld pak 175hd both from home depot any bad things about these 2? I would like to hear from you guys before I make the decison not looking tospend more than$650.00 also maybe would weld some aluim.   Thanks in advance
Reply:175i have the 3200 and while i love it i somtimes wish i had gotten the 175. luckily i have the ability to stick weld all the thicker stuff. it is nice to have the portability though.Millermatic 211weldpack 3200 squirtgunsquare wave 200victory journeyman kitHypertherm 30xptoo much other crap to listtinkerer extraordinaire
Reply:IF you are thinking aluminium keep in mind the need for a bottle of argon and for your sanity a spool gun. Better figure on a 220 volt unit too, 110 volt is going to come up short on power.Lincoln PT185 TIGLincoln 175 MIGLincoln 240 amp AC StickLind Needle Arc plasma welderPlasma cutter, soon???
GMT+8, 2026-1-1 00:21 , Processed in 0.113483 second(s), 18 queries .
