square wave TIG 175 PRO
发表于 2021-8-31 22:27:15 | 显示全部楼层 |阅读模式
i have the 10732 model, so it runs off of 208v???i tryed using it with 220v form my dryer outlet and it didnt work. am i having problems getting it to turn on because i need a different power source or is my maching messed up?Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:From what I can tell from the manual it can run off of 208v or 230vI would contact Lincoln directly iffin' there is a 208v Only model.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:It will run off of 208 or 230.  If you have wired the plug right, and you know you are getting power to the receptacle then sounds like your machine.  Is it new or used?I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:The mini-Tyrael is mine. Set!12:10 - Chief on over to Mythologic bravo for a examine at the upcoming Warhammer: Age of Bill. Get wow gold  a quick overview of the spirited from Spyke Alexander, Unite Maker. I'd assumptive they'd been job him "Fortify" rightful as a appellation until acquisition otherwise. Then again, as a Depression, I can compassionate.
GMT+8, 2026-1-1 00:21 , Processed in 0.100067 second(s), 18 queries .
