Purchased an Eastwood TIG 200 AC/DC on 12/18/2012. Here is my first welding table project.Top plate: 2'x4'x1/2"Frame: 3x3x3/16" front and rear rail, 2x3x3/16" sidesLegs: 3x3x3/16"Bottom shelf: 2x3x3/16"Clamp rails: 2x2x3/16"This is a work in progress. My plans will include 4 receivers (2 1/2x 2 1/2x 3/16") that will allow me to mount grinder, drill, etc. on 2x2.Added Bottom self: 3/16" steel plateCut out 3x3x3/16" front and rear rail with plasma cutter to allow for receiver mounts.Will be purchasing caster and mounting to table on next task.http://www.castersupply.com/NAV/gd_100.htm
Reply:Welcome. You got some really cool ideas there. I like that table.
Reply:Wow, that's a nice welding table.. Are you sure this is your first project?
Reply:Nice, that is a lot of iron there. I did see those casters posted before but have not heard how they are liked. That sure is a small wheel. Not to be fussy but the propane tank and gas container should be relocated IF that is where you were welding. Never can be too safe.
Reply:That is a great table. Did you have a shop cut the slots in the top or did you do that? Nice job.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Impressive first project...... We will need to see lots of photos of your future projects.Qualified & experienced at welding scrap metal
Reply:I must expand my fabrication/welding skills. That's a professional work. Great job.PlasmaCam CNC cutterLathe and Band SawClamps |
