Couple Of Small Projects!!!
发表于 2021-8-31 22:27:15 | 显示全部楼层 |阅读模式
I have a lamp in front of my home that either needed replaced of redone...........I decided to redo it. The lenses were ugly and yellowed. I decided to replace them with expanded metal. I am using a a halogen bulb.........we will see how the weather treats it. I also made an adjustable plant hanger out of 1 inch 304 stainless strap. The wife's birthday is coming up and thought I would do something original using my skills and what ever I had laying around.........I did purloin the copper from work and the only cost was a rattle can of clear.
Reply:Nice.
Reply:Looks good.
Reply:Nice work!
Reply:Very nice!Mike
Reply:I'm impressed with the well-executed job on the rose. It looks amazing.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Good job on all the projects.You may have to put some glass inside the expanded metal to keep the rain from cracking the bulb. You should be able to make a cardboard template and have the glass cut fairly inexpensively. Then just use some black silicon around the edges.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
GMT+8, 2026-1-1 01:56 , Processed in 0.102597 second(s), 18 queries .
