dock ramp
发表于 2021-8-31 22:27:13 | 显示全部楼层 |阅读模式
Had a guy Ive bought some stuff from before give me a call saying he needed some welding. Basically the people he works for have a lake house. The ramp to the floating dock had pretty much deteriorated. He asked my to fix it. I told him i needed to build a new one. Install will be tomorrow, Ill get a pic of what used to be there. It was just a short piece of angle for the hinge and then all wood. there is a hole going through the angle with a piece of pipe to pivot. The bottom end is loose setting on the float dock.- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Looks pretty sharp!
Reply:Got rained out last night so I went this evening. Using the existing brackets the install took about 5 mins. The customer was happy. - Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Pretty cool!!What'd you bid it??
Reply:cam; the ramp looks good. did you notice if the original ramp pivot point where the pipe went through was worn at the holes?i.u.o.e. # 15queens, ny and sunny fla
Reply:I got 200 for the job installed. Doc... There was only one side left. The cut was done with a torch and was rough but I'm not too worried about the design. The last one lasted a long time. The whole dock is falling apart. I'm sure this ramp will outlast the rest!- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
GMT+8, 2026-1-1 03:51 , Processed in 0.111532 second(s), 18 queries .
