iron gate
发表于 2021-8-31 22:27:13 | 显示全部楼层 |阅读模式
here's a gate i  just finished,all the horizontals are punched w 11/16 square holes to accomodate the 5/8 pickets,small back welds so there are no visible welds. Attached Imagesface all times with a positive mental attitude,then and only then will you have done your best.
Reply:Nice job!ECAVE Still learnin'Lincoln AC225Lincoln 135SPHF ChopsawVictor O/ANumerous other items
Reply:Very nice sir.   What type of hinges will it have and is that the latch rod I see between one of the end verticals and a picket?
Reply:Looks great!!  Did you use an ironworker to punch the holes?
Reply:iron gate, nice gate!
Reply:the  cane pole in place of a latch, this way it can be pegged open. the hinges are simple 1/2 barrels w/a 6"x5/8 rod welded to one side and epoxied into a concrete filled block wallface all times with a positive mental attitude,then and only then will you have done your best.
Reply:yeah, i have a 60 ton buffalo machine.....great thing to haveface all times with a positive mental attitude,then and only then will you have done your best.
Reply:No in fab pics??How do we know you did it???
Reply:That's a superb job. There's no way I can make like that. Well done.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Great looking gate.
Reply:didn't take any in the makingface all times with a positive mental attitude,then and only then will you have done your best.
Reply:Nice, I like the radius and the rings . Is that a harbor freight roller in the background on table ? That thing does work ok for the money. Do you use it much ?
Reply:great looking gate.  what did you use to put the curve in the top rails?i.u.o.e. # 15queens, ny and sunny fla
Reply:Looks good!
Reply:Nice looking gate - I even like the color since it reminds me of Ford blue Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:i used a harbor freight roller   with a frame i modified, and i took 1/2 groove rollers zand machined themk out to about 1 9/16+ .it works ok..face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Originally Posted by iron mikei used a harbor freight roller   with a frame i modified, and i took 1/2 groove rollers zand machined themk out to about 1 9/16+ .it works ok..
Reply:i buy the rings from an ornamental supply company.they are 1/2" square bar stock, the pickets are 5/8. the big companies have machines and folk that spit those things out by the thousands, i think they only cost me a buck or so each.'face all times with a positive mental attitude,then and only then will you have done your best.
GMT+8, 2026-1-1 00:20 , Processed in 0.097108 second(s), 18 queries .
