查看: 13|回复: 0
What is the purpose of a second bend on flux core gun necks?
发表于 2021-8-31 22:27:07 | 显示全部楼层 |阅读模式
I am ordering a Profax model #1260 350a flux cored gun this week and when looking at the product sheet they list 30deg and 50deg necks with single and double bends. What is the purpose of the second bend, does it help for vertical welding on structural stuff because it points the wire upward?I'll be running .035 & .045 wire and will most likely go with the 15' gun with the 50deg neck, but might pick up the 30 just in case but dont know which one to get.Thanks,ChrisTOO MANY TOOLS & NO MORE SPACE
Reply:It just changes the angle of the gun and the distance from you hand to the work. A 50* single  puts the nozzle 50* from the handle,whereas a 50* double might bend back 10* at the end. Just a comfort thing I would think. I have never had a need for a double bend, but I dont do hours and hours of FC welding.
Reply:Just curious.  Who does hours and hours of FCAW?Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Originally Posted by storemanJust curious.  Who does hours and hours of FCAW?Jerry
Reply:The up tick on the end of the flux core guns is specifically for NR-232, it helps straiten out the wire and keep it running into the contact tip at the same spot.      None of the other flux core wires really need the second kink in the neck.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Thanks for the help, I will go ahead and order the single bend necks.Sent from my SPH-L710 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:Squirmy and CEP, thanks.  Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Originally Posted by storemanSquirmy and CEP, thanks.  Jerry
Reply:a light month is usually 150lbs  a heavy month can get over 400Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2026-1-1 07:22 , Processed in 0.134896 second(s), 18 queries .
