small fluxcore wire that is approved for d1.8?
发表于 2021-8-31 22:27:05 | 显示全部楼层 |阅读模式
Is there such a thing as .035 or .045 gasless fluxcore that is approved for AWS d1.8?Ian TannerKawasaki KX450 and many other fine tools
Reply:ESAB Coreshield 8 carries that rating from what I remember but the smallest we could get at the time was 1/16".
Reply:1/16th is the smallest i have ever seenVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:1/16 was the smallest I could find too. I wonder why they don't make a small one? Maybe not enough demand?Ian TannerKawasaki KX450 and many other fine tools
Reply:1/16-inch T-8 wire will run about like 1/8-inch 7018 for vertical up, or you can kick it in the a$$ and it will run like 5/32 or 3/16-inch 7018 flat. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
GMT+8, 2026-1-1 03:51 , Processed in 0.119315 second(s), 18 queries .
