affordable finger brake??
发表于 2021-8-31 22:27:05 | 显示全部楼层 |阅读模式
I need a 4' box and pan brake. The HF and NorthernTool offers a too light weight for me. I want one that will work 14ga. but can't find one that don't cost thousands. Can any one suggest a manufacture?Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:grizzly #g0542 48" and up to 12ga $1695.00 Attached Images
Reply:Originally Posted by waginI need a 4' box and pan brake. The HF and NorthernTool offers a too light weight for me. I want one that will work 14ga. but can't find one that don't cost thousands. Can any one suggest a manufacture?
Reply:I am  surprised that you dont make your own  ....you can cut and weld...? a very simple thing to make
Reply:I'm afraid I'd have to disagree. To put a fair value on your time plus materials...you'd be in for a lot more than $1695. JMHO
Reply:Originally Posted by jwormanThis probably won't do, but Tractor Supply has a 36" brake that they say will bend 12ga steel for $249.  I saw one the last time I was in a store (120 miles away) and I was impressed.  I'm not sheet metal worker, so I may have not seen what should be seen.Anyway, it's smaller than what you want, but it's cheaper than some.http://www.tractorsupply.com/welding...-36-in-3805140
Reply:Originally Posted by MarcuspboldtI don't think that is an actual finger brake though.
Reply:Definitely buy used or at auction.And I for one have never exceeded the rated capacity of a manual brake. No, never.
Reply:man if you do find one that is manual, I want to see a picture of the man who will be using it at 12 ga for any length of time.  I used one and it was tough.  The one I used was a copy of the grizzly.  you have to be a man to use it all day long.  I offered to buy it so I could put hydraulics on it, but the guy didn't want to sell it.
Reply:I wouldn't trust the northern ad.  It is probably 12g at about 12 inch wide.  Not a finger brake, either.  read the reviews.
Reply:ed mac, Thanks! exactly what I'm looking for. The price is right too.JoondeerMan....If I had the 30+K of machining equipment required to produce a finger brake, the labor hours would not compute.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Originally Posted by tapwelderI wouldn't trust the northern ad.  It is probably 12g at about 12 inch wide.  Not a finger brake, either.  read the reviews.
Reply:Originally Posted by wagined mac, Thanks! exactly what I'm looking for. The price is right too.JoondeerMan....If I had the 30+K of machining equipment required to produce a finger brake, the labor hours would not compute.
Reply:Wagin,I'm also looking at a B/P brake similar to what you want...12 ga...48".  I'd really like to here your feedback when you get yours.I've seen the ads for the Grizzly brake that EdMac suggested and it looks like it might work.  I have several tools/machines from Grizzly and have been satisfied...more or less.  The Chinese stuff Grizzly sells has always got the job done but there's usually quality issues that the pictures and specs don't show.  The handles fall off.  The screws get loose.  The wheels or mounting feet are crap.  They always need tweaking to get accurate results.  But the stuff is 1/3 to 1/4 of what quality US mfg'd items costs.  For production work...no way.  For my home garage/shop...sure.I am also the sad owner of a 12" HF bench top combo press brake / shear "thing".  Trust me...don't ever get one of those.  It won't brake, bend, or shear anything.  I honestly doubt that it would be an acceptable boat anchor.  Pure junk.Miller 211 w/ spool gunMiller Dynasty 200DXLongevity 60i IGBT plasmaO/A w/ crappy chinese torch/gaugesSouth Bend 10K latheGrizzly 4029 10x54 millGrizzly 7x12 hor bandsawangle grnders, bench grnder, bench belt sndr7.5 hp 80gal cmprsor
Reply:TRy searching Northern Tool as they have some really nice metal brake and combo units from a couple hundred to over five thousand $$$$I know if you order on catalog you can have delivered local Northern at no shipping cost (at least they did for me on several items)(PS I noticed several listed have FREE SHIPPING to your llocation)http://www.northerntool.com/shop/too...atchallpartialLast edited by specter; 01-28-2011 at 04:14 PM.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:combos bite
GMT+8, 2026-1-1 00:19 , Processed in 0.181549 second(s), 18 queries .
