Where can I get parts for my SA-250?
发表于 2021-8-31 22:26:58 | 显示全部楼层 |阅读模式
My welder is pretty old but after going through hurricane Gustav it really made my life easier and me appreciate it a lot more. I had no power for 4 days and my welder kept everything in my fridge/freezer good, the wife busy with powering the TV, & lights. After having it run for hours at a time on my carport I did wish it was quieter. I need a muffler and possibly an exhaust manifold, the old muffler rattles and the base plate is all bent up not allowing a good seal on the manifold. Anyone have a clue where to get parts for such an old welder?Really old (&faithful) Lincoln SA-250 Diesel, &Longevity 200P
Reply:any good muffler shop should be able to fix you a muffler.  as far as the manifold what engine does it have in it?I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Got the 3.152 Perkins? If so, we have everything for it. A few of these came out with the Continental TMD27 engine.weldersales
Reply:Hope all you had was power outage as a result of Gustav WS6HUMMER.  I don't wish bad fortune on ANYBODY but I'm glad he stayed on your side of the Sabine.  Just wish he'd stayed away completely for your sake.Need anything else?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by Hammack_Weldingany good muffler shop should be able to fix you a muffler.  as far as the manifold what engine does it have in it?
Reply:Originally Posted by WS6HUMMER I wish I knew what year and what engine, I'll try to look closer for an ID tag somewhere. Do you know of an easier way to tell?
Reply:Originally Posted by denrepPerkins 3.152 is a three cylinder, TMD27 is a four.Hope it's a Perkins; probably is, they llike to shake the exhaust manifold loose.Good Luck
Reply:Originally Posted by WS6HUMMER...Man It sucks that I now know its got a Perkins, my dad has 3 parking lot sweepers that have those same engines...We just crushed 2 extra parts trucks...
Reply:Originally Posted by denrepActually nothing sucks as bad as trying to buy Continental parts. You have a far better engine.Junking Perkins engines - That hurts!Those engines aren't throw-aways yet. In sweepers they probably had torque converters or hydrostats on ‘em too. Ouch!
Reply:Originally Posted by WS6HUMMERYeah, I could kick myself now.
GMT+8, 2026-1-1 05:35 , Processed in 0.219657 second(s), 18 queries .
