Lincoln promig 175 value??
发表于 2021-8-31 22:26:57 | 显示全部楼层 |阅读模式
I  posted this in the lincoln forum but thought I should ask here.I need to know what to offer for this promig175See this thread for more info pleasehttp://weldingweb.com/vbb/showthread.php?t=23983
Reply:If it is basically new, you are going to be fair, and in good shape to offer 350-400. If the regulator is there, then don't hammer the guy too hard, 400 is fair. That welder will live for 20 years, so it is a worthwhile investment.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
GMT+8, 2026-1-1 03:49 , Processed in 0.111067 second(s), 18 queries .
