SA 200 radiator hose part #
发表于 2021-8-31 22:26:55 | 显示全部楼层 |阅读模式
Anyone have the gates/dayco part number for the radiator hoses?  I have a 1978 SA200.  I would like to be able to go to any auto parts and buy the hose.Thanks in advance,CharlesMillermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
Reply:Upper hose: Gates 20606Lower hose: Gates 20705The proper hose is "in" those part numbers, that is you need to cut a bit off of each end. You can lay your old hose against the new one and mark/cut it or if you don't have the old ones just hold it up there and mark it. Better to have to cut it twice than go get another one ; )Copied from aws forums
Reply:Originally Posted by rmkrider1Upper hose: Gates 20606Lower hose: Gates 20705The proper hose is "in" those part numbers, that is you need to cut a bit off of each end. You can lay your old hose against the new one and mark/cut it or if you don't have the old ones just hold it up there and mark it. Better to have to cut it twice than go get another one ; )Copied from aws forums
Reply:A memorial that hangs warm the crucifix reads that wow gold  Actress dedicated it to his dead spouse. Also registered are others whom he always had heavy attachments to, plane after he enraptured out of Danville in 1980.
Reply:Anyone happen to have the part # for the bypass hose?  This is the curved hose that is about 5/8" id.Millermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
Reply:I found a Gates heater hose that worked.  Had to cut about 1.5" on the long end.Gates part # 18955 Attached ImagesMillermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
GMT+8, 2026-1-1 03:49 , Processed in 0.136934 second(s), 18 queries .
