drop down work table for welding rig
发表于 2021-8-31 22:26:53 | 显示全部楼层 |阅读模式
threw together a small table on the back of my truck. nothing fancy, just something to set tools or weld small parts wherever I may be, or do some tig work on. I added a small 1/2'x2" long pipe on backside and drilled a hole in the bed and dropped a rod through to keep it pinned up. the table is 2'6" x 1'6" made out of 1/4" plate.R.T. Welding LLCOn Site ServiceColumbus, NJ
Reply:Really Nice!!Millermatic 211Dewalt 14" ChopsawDewalt 4 1/2" GrinderCraftsman
Reply:Clever and I bet  going to be very handy.
Reply:radius those corners of before you hurt yourself, you'll be glad you did. nice table...it'll be real handy in the field!face all times with a positive mental attitude,then and only then will you have done your best.
Reply:it beats working off milk boxes or the truck bed. good idea!i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by iron mikeradius those corners of before you hurt yourself, you'll be glad you did. nice table...it'll be real handy in the field!
Reply:Might want a piece of rubber under those supports to protect the paint against friction. Rust is bad.Just a thought."I thank God for all the freedoms we've got in this country, I cherish even the right to burn the flag, but I'll tell you what, we've also got the right to bear arms and if you burn my flag I'll shoot you"-Johnny Cash
GMT+8, 2026-1-1 03:50 , Processed in 0.100880 second(s), 18 queries .
