查看: 2|回复: 0
another base edge
发表于 2021-8-31 22:26:53 | 显示全部楼层 |阅读模式
did this other day 48"off cat 330 1.86yd. Attached Images
Reply:That is a lotta work in that one picture, nice work as always.Ranger 250 thick stuffHobart Handler 140 not thick stuffthe pane and oxy setup
Reply:Looks good how bad was the old lip?
Reply:Originally Posted by Firemanmike69Looks good how bad was the old lip?
Reply:Nice job, does the front edge and teeth come as an assembly or do you buy the parts and weld it up.TOO MANY TOOLS & NO MORE SPACE
Reply:Originally Posted by Chris T.Nice job, does the front edge and teeth come as an assembly or do you buy the parts and weld it up.
GMT+8, 2026-1-1 01:54 , Processed in 0.099800 second(s), 18 queries .
