Someone Needs To Learn How To Measure....
发表于 2021-8-31 22:26:51 | 显示全部楼层 |阅读模式
I came in to find these waiting for me...These are usually bent (Yes It Was) and we cut off the rod end and turn and thread the piston end...Note says..."We will take off the big end and replace it so just turn and thread the end the piston goes on"Easy enough I say to myself..After lining up the ends I notices a slight problem..Someone forgot to add the last 3.5 inchesSo there is only one option seeing they are not going to spend any more $$$$$ for a new piece..(4"OD Chrome Plated Shaft 92" Long)...Time for a new end.New End...Bore and counterbore in the shaft...One more time......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:So now we heat the rod end and install the new threaded end..   .003 Shrink....Weld after cooling somewhat...(yeah I know they suck but what do I care...being turned off anyway..)Now to see how good I really am...Using the center hole in the threaded end and NOT using a steadyrest it's time for the indicator "De-liar"...Set to zero...Turn chuck 180 and see how much it runs out....001 is excellent!....(Sorry .. Got The Pics Backwards..)Face end weld and now we are done...There.A perfectly undetectable repair.I get all the fun jobs......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Mad skills.  I don't NEED to be able to do that kind of thing, but I WISH I had the ability!  Nice...
Reply:Hey, that's why you get the BIG BUCKS !          Plus, what's 3 1/2'' among friends ?
Reply:Awesome Zap!  Picture of the lathe you turned that on for clean up please.  What is its internal capacity?Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Cool bro! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Nice job as always.  Just as a point of discussion I believe I would of done it a little different. I would of drilled and tapped the rod at which point there's several ways to go from there. My favorite would of been to just used a grade 8 bolt to bolt the piston on. I've seen several heavy duty cylinders which that is the attachment method from the factory. Less work that way. But you could of made a stud to of screwed into the rod as well.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Originally Posted by irish fixitNice job as always.  Just as a point of discussion I believe I would of done it a little different. I would of drilled and tapped the rod at which point there's several ways to go from there. My favorite would of been to just used a grade 8 bolt to bolt the piston on. I've seen several heavy duty cylinders which that is the attachment method from the factory. Less work that way. But you could of made a stud to of screwed into the rod as well.
Reply:Originally Posted by storemanAwesome Zap!  Picture of the lathe you turned that on for clean up please.  What is its internal capacity?Jerry
Reply:Originally Posted by zapsterThat was discussed but we do what they want.I try not to argue anymore....zap!
Reply:Zap, all of us are usually good at something. Maybe, just maybe I might be better at something than you. Notice I said maybe! Anyway, it is a joy to see the work of a true CRAFTSMAN, and I mean that as the highest compliment! You take great pride in your work, and it's something lots of us can relate to. Sad thing is I've chit canned rods before never knowing it were possible to repair. Live and learn, huh.                   ChuckTo ride, shoot straight, and speak the truth. This was the ancient law of youth. Old times are past, old days are done, but the law runs true oh little son.Winpower 180 DCSA-200 redfaceXMT-304
Reply:Originally Posted by sled dogZap, all of us are usually good at something. Maybe, just maybe I might be better at something than you. Notice I said maybe! Anyway, it is a joy to see the work of a true CRAFTSMAN, and I mean that as the highest compliment! You take great pride in your work, and it's something lots of us can relate to. Sad thing is I've chit canned rods before never knowing it were possible to repair. Live and learn, huh.                   Chuck
Reply:No way man! You were just doing it a different way to break the monotony!             ChuckTo ride, shoot straight, and speak the truth. This was the ancient law of youth. Old times are past, old days are done, but the law runs true oh little son.Winpower 180 DCSA-200 redfaceXMT-304
GMT+8, 2026-1-1 01:55 , Processed in 0.072142 second(s), 18 queries .
