Skid steer land plane
发表于 2021-8-31 22:26:51 | 显示全部楼层 |阅读模式
built this to use with me skid loader its a land plane to level dirt gravel and whatever else they work great on driveways. its 72" wide about 48" deep. it will have scarifier teeth on the round stock that hydraulically raise and lower they will be to rip the ground to get me level. still have to add cutting edge on back and front. no professional welder here just do what i can. really enjoy making things like this, have done a couple other projects like this before ill post some more later. thanks for looking. Attached Images
Reply:Nice looking welds.  What's the wall thickness of that tubing?
Reply:tubing is 3/16". the attachment plate i bought pre made. i still need to get the teeth also. Attached Images
Reply:Nice job.
Reply:Interesting, what will the mesh's purpose be?
Reply:rock collection.
Reply:How big is the skidsteer?Also will you be pushing or pulling the implement?"I thank God for all the freedoms we've got in this country, I cherish even the right to burn the flag, but I'll tell you what, we've also got the right to bear arms and if you burn my flag I'll shoot you"-Johnny Cash
Reply:60 hp. and it can go either way planing the scarifying only go in reverse tho.
Reply:I have had several types and Im not very impressed with the ones i have used, Bobcat 763, I'm waiting for a known good design to come along. dragging works better but dragging with a skid is a pain in the neck, and the kids know better to look the fork out when i'm dragging.....u will have to post your results.....
Reply:well got some more work done on it over the past couple days. cylinder works pretty good. going to put two more sleeves in center on each side of the cylinder for extra stability. the shanks came today way cheaper to order them and have them shipped saved almost 250$ compared to what a local dealer wanted for them. anyone have any other suggestions to make it a little better?
Reply:more pictures Attached Images
GMT+8, 2026-1-1 03:52 , Processed in 0.119931 second(s), 18 queries .
