Help with welder look up
发表于 2021-8-31 22:26:50 | 显示全部楼层 |阅读模式
I am trying to find the right manual for my welder. Its a miller bobcat 225g plus. Serial # KG081980 stock #903372. I have been on millers website and typed in the numbers and nothing is showing up for the serial number?
Reply:Try this oneSent from my XT1030 using Tapatalk
Reply:Oops. http://www.manualslib.com/manual/103...bcat-225g.htmlSent from my XT1030 using Tapatalk
Reply:Not sure if the same   http://powertool.manualsonline.com/m...bcat_225g.htmlSent from my XT1030 using Tapatalk
Reply:https://www.millerwelds.com/files/ow.../O403C_MIL.pdf
Reply:Thanks for the response. The number had me a little confused because if the number. And when I typed it in the look up box it came back no match. If the Ines you both sent are close enough I'll go with it. And again thanks.
GMT+8, 2026-1-1 01:54 , Processed in 0.103714 second(s), 18 queries .
