MIGing 409 with 70S6
发表于 2021-8-31 22:26:46 | 显示全部楼层 |阅读模式
I need to do a little work on my exhaust. At this point the only welder I have is a 175HD and the only bottle I have is CO2. Should it work ok as long as I don't need corrosion resistance?Lincoln 175HD
Reply:Should work fine. I welded plenty exhaust with steel wire and never cracked
GMT+8, 2026-1-1 01:54 , Processed in 0.097090 second(s), 18 queries .
