Tig critique please
发表于 2021-8-31 22:26:45 | 显示全部楼层 |阅读模式
1/4" stainless angle iron cut down the spine to make a 45degree bevel. Root pass 3/32 316 stainless 63 amps 75ar 25he 15cfh hot passes coming next. Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Pass # 2 100 amps everything else the same Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Passes 3&4 3 on the bottom 4 on top of pic same every thing except arc length on pass 4Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Pass 5 same everything lots of washing to cover full width. Let me know what you think Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:The last one was too ugly so I had to go over it again it wasn't too bad in person but the camera doesn't lie.  Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Come on people give me your 2 cents. 104 views and no replies really? I've got maybe 6 hours behind the hood with a tig torch. Any tips to help my technique would be appreciated. You won't hurt my feelings let me have it.Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Originally Posted by Austin BennettCome on people give me your 2 cents. 104 views and no replies really?
Reply:Looks like you overheated it welding cold/slow. I can't see much from my phone though.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Thanks dsw sorry for the impatience. Not looking to do any specific type of welding. I would like to do it all eventually. I chose the stainless because it easy to prep. As far as heat I will try cranking it up and going faster. I also need bigger filler 3/32 felt too small after the #2 pass. No I didn't shield the back of the root. I will work on my basics thank you again for your time.Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Yeah squirmy I heated the heck out of it. Maybe the scrap yard will give me copper prices for it.Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
GMT+8, 2026-1-1 01:55 , Processed in 0.097115 second(s), 18 queries .
