Tig on off foot switch
发表于 2021-8-31 22:26:44 | 显示全部楼层 |阅读模式
I'm thinking of fabbing a simple on off switch   To use while tig welding with my Ta 211. I have two Honeywell micro switches rated at 15a 125v,250v or480vac. It is a 3 tab switch so it can have contact open or closed. Or both. Yeah I should just buy a foot pedal but really have no need for one. I'm welding dc only and downslope while working the torch switch is good. I just want to steady my torch hand by not having to push the torch mounted switch repeatedly. Attached is a pic of the switch I have two of them. Any thoughts, suggestions,warnings and help would be greatly appreciated. Thank you in advance Austin. Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:I'd recommend reading your owners guide....  Subtle hint, http://thermadyne.com/IM_Uploads/Doc..._March2013.pdfPage 3-12, the section entitled "Remote Control Socket" I doubt that circuit even pulls 10 milliamps.   Those snap action switches will be fine.  Off = open, On=closed circuit.  Chose the two pins that match that functionality.  You want the output pin labeled "NO" which stands for Normally Open (and not the pin marked NC = Normally closed)Now you've got to build a foot pedal that works with those switches (no easy task. ) I may be much easier to add the switch to an existing foot pedal.  I'd probably stay clear of the plastic sewing machine foot pedals.  Find an cheap music foot pedal...
GMT+8, 2026-1-1 03:50 , Processed in 0.102896 second(s), 18 queries .
