I think I got a great for for 175 for the deep cut saw and stand and legs. I have wanted one for a very long time but the price was waaay to high. I was amazed to see how fast it cut some small angle irons. This will really make cutting metal for me much easier. I have a really odd piece of about 5" square aluminum ibeam. I wanted to try to slice it into 1" pieces and maybe make some neat stuff from it. It started cutting very well but 1/2 way through the blade just bent and finished th cut with a massive mis-angle. Not sure what I am doing wrong, any ideas what I need to do to help keep it straight?
Reply:The blade likely got loose, or guide slipped, or the blade gummed up with aluminum. When cutting large pieces of aluminum I always use saw blade lube, or paraffin, or WD-40.
Reply:I bet it gummed up. I use pam cooking spray.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:What's the tooth count? For aluminum you'll need a pretty coarse blade. It could have been gumming up."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:I will check it, I think I have an 18, maybe I need a coarser and I will definitely try the lube
Reply:Another issue is that the milwaukees are kinda heavy so you can't always just lay it on there and let it cut its way through, especially on aluminum. Even tho it's heavy and the aluminum cuts like butter you'll have to hold it back and guide it through."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Aluma Cut, mfd by Walter. Works good if you want to buy something at your LWS."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:I think I found a big part of the problem, I didn' realize that there are adjustments on the base for the arm, and they were basically square with the back of the base, but not square with the work clamp which is really what matters, so I made the adjustments and its about 100x better. I think with a portable you aren't going to have it perfect but it made a big improvement on the squareness of the cuts. Now if I can just make more space in my tiny workshop for these toys! |
