I can hear the hole saw scraping and squeeking its way through tthe piece..At the same time there is horrible noise comin from the head of the press...When I use a holesaw it sounds like a flock of geese getting hit by a feight train.Its an el crappo drill press, just wondering if any of you with the better drill presses hear this sound.I Know about the lack of rigidity in mine etc
Reply:Sounds like it's belt driven. If it is, check the belts for wear and proper tension, they may need replaced also.Are you using any cutting fluid with the hole saw?Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:Slower speed and plenty of cutting fluid.Tim Beeker.
Reply:I've got a conventional drill press that does the same thing at times. It's the bit chatter that transmitts across everything thing on the press. Even the lid over the belts rattles out some of the noises. You'd have to dampen the noise at several locations to have any real accumulative affect. I have a Jet mill drill, no problem. Quiet as can be."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:That's life.Get used to it....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:first off is the drill press secured to the floor or table? sounds like chatter, slow your rpms down, make sure the workpiece and table are clamped securely, use some kind of lubricant, i generally use 5w30 synthetic oil becuase i have it handy in the garage..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Mine makes all kinds of racket as well while hole sawing. Just the nature of the hole saw being "grabby". It doesn't sound good for the drill at all. |
