Milwaukee 6230 bandsaw
发表于 2021-8-31 22:26:37 | 显示全部楼层 |阅读模式
I have this portable band saw, and the blade keeps slowly pushing itself off the rollers when I power the saw up.  I see no adjustment for the pitch/angle of the wheels.  Am I missing something here?  Help.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:go all around the saw and make sure every screw/bolt is tight especially the blade guide to the rear.  also make sure the tires on the saw are pushed all the way down and are not worn. these are the adjustments i have had to make to all of mine to keep the blades from walking.
Reply:Thank you.  I will try that tonight.   The tires are definitely in place.  Do the roller guides play any roll in keeping the belt on?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2026-1-1 03:50 , Processed in 0.097892 second(s), 18 queries .
