what size hole is recomended
发表于 2021-8-31 22:26:36 | 显示全部楼层 |阅读模式
rather than buy a door for my bobcat, i will make one, i'm doing the hinges now, but I want the pin to be a nice tight fit, but not too tight. so my pins are .390" my drill bits go .390 then next size is .400 even the numbered bits are about the same, i thing 10 thous. is to sloppy, so what would the ideal hole size be? I hate to buy a special ream for one job, any suggestions......
Reply:.010 for a door hinge on a bobcat is nothing..You could just use the .390 and ten to one it will drill oversize anyway..In reality it's only .005 per side and a good dose of grease will be more than enough cushion..You don't want them too tight..All that twisting and banging.........zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapster.010 for a door hinge on a bobcat is nothing..You could just use the .390 and ten to one it will drill oversize anyway..In reality it's only .005 per side and a good dose of grease will be more than enough cushion..You don't want them too tight..All that twisting and banging.........zap!
Reply:Hey 1awert1,+2 on using the .390 you have. A gentle "wiggle" while thru will expand that hole at least .005. More than adequate "slop". Definitely some lithium grease.DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:If it ends up being to tight just stick the pin in drill chuck and take a piece of sand paper or emery cloth and polish it up a bit. You aren't going to remove much but it will probably help it slide in. By the way I have never met a twist drill that will make a perfect hole the exact size of the bit even in lathe or mill.Millermatic 252Lincoln 175 plusTA 185tswTA 161stlhypertherm pmax 45Victor torchHenrob torchAn S10 for each day of the week
GMT+8, 2026-1-1 01:53 , Processed in 0.131311 second(s), 18 queries .
