Milwaukee mag drill gears
发表于 2021-8-31 22:26:36 | 显示全部楼层 |阅读模式
I picked up a used milwaukee mag drill with a stripped gear. I ordered the parts, but not sure how to get the gears out of the case. I need the center one out. Thanks for any help. Attached Images
Reply:Reach right in there and just pick them out. start with the left one first.  Then the next one.  There should not be anything holding them in except greese. The right one will be held in by the chuck   Mac
Reply:Go to this Milwaukee Site and enter your model number, select the first box to see the parts breakdown, .... and have fun....http://www.milwaukeetool.com/parts-s...wnload-manualsYou might also need to see which breakdown to select later, based on the serial number..Last edited by Oldiron2; 10-08-2011 at 10:44 PM.
GMT+8, 2026-1-1 03:51 , Processed in 0.070586 second(s), 18 queries .
