making 1 from 2
发表于 2021-8-31 22:26:36 | 显示全部楼层 |阅读模式
we're pulling our hair out with a problem and in researching it there seems to be a great knowledge of the macines in question here. we have 2 faulty Lincoln Onan engine machines and we are trying to make 1 out of 2. all i need is the welding and power circuts for the units but have had no luck. the 2 machines are:a) Linkwelder 225, DC ARC Welder with DC power. code 262. b) WeldanPower 225DC Model DC-225/3-AS. we want to base the working model on the WeldanPower as it the newer of the 2 Onan engines. So far the only result i have is that the engine wants to run backwards and wont start. We have asked a few good electricians to look at it but without a welding and power curcuts for the units they are not having any luck.We have tried to contact Lincoln New Zealand and Australia but with no luck. Could you please give us some direction?Do you have a copy of the diagram we are looking for?any help would be appricated. Thanks very much
Reply:I believe you'll find that DC-225/3-AS is a Lincwelder model as well rather than the later and different design Weldanpower but that said it sounds as if the brushes are wired backwards which would explain why the engine is cranking opposite that it should.  These units use the generator rotor for cranking and I believe reversing the polarity on the brushes will do that although not 100% sure.Here's a couple machine diagrams that were posted up before in another thread that should help.  They may not be exact for these particular machines as there were slight differences in the battery charging circuit depending on the age of the unit.M10148.pdfS12953.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Hi Duaneb55, thanks for the responce. we tried swapping the polarity of the bushes but the current came up to 700 amps. it was smoking up pretty bad. i thought that it should opperate around 200 or so. i'm going to have a closer look at the machines and the diagrams you attached. appricate the your time and your reply. thanks very much
GMT+8, 2026-1-1 01:54 , Processed in 0.109954 second(s), 18 queries .
