gas problems w/180
发表于 2021-8-31 22:26:35 | 显示全部楼层 |阅读模式
I have been welding with flux core with no problems when I switched to gas,solid wire using 75/25 it seems I'm not getting gas to the nozzle, I'can't seem to trouble shoot, can anybody point me in the right direction, Thanks
Reply:Assuming polarity was switched and your solenoid is working properly( at least hear it clicking when trigger is pulled).  Also, gas in cylinder.With my lincoln 180 the cable must be fully inserted into the power lug, otherwise the o-rings will not seal and gas will escape at the lug.  I also, had one (Lincoln 180c) that wouldn't seal and was replaced.Might want to add some specifics to your post, if you don't get it solved.
Reply:Your going to have to get more specific on the type of feeder and such, can't pull a wiring diagram out of thin air...
GMT+8, 2026-1-1 03:52 , Processed in 0.110617 second(s), 18 queries .
