Latest Home Cheapot Deal...........
发表于 2021-8-31 22:26:34 | 显示全部楼层 |阅读模式
I ALWAYS look all around Home Cheapot and Lowes when I am there as they have clearance stuff in odd places.So the other day I am in HD  and I see a Lincoln AC225 in a ripped up box. I look at it and see that they have sprayed the dreaded Orange paint dot (clearance) and scribed in a reduction date with an electro pencil.Original price was $269, clearance reduction was $140. Upon further inspection, the tag says reduced because of "damage" Reason listed as "cut wire". So I start by pulling the electric cord/plug out, it is perfect. I then pull the ground lead out, perfect again, I then pull the hot lead out and see the end of the lead has the insulation stripped and bare wire in the last 2 inches. There are no cuts in any of the wires.I look in the back of the welder and find the manuals envelope, the ground clamp, the assorted sample rods pack. I tilt up the machine and find the brand new electrode holder with cover at the bottom of the box.I determine that the wire has never even been mounted, just the end is frayed a bit. I ask the guy if it can be marked down any more as it was more than a week since the first one. He asks the Mgr. who says..............................................  ..................................................  ..................................................  ...$80.68SOLD say's I.Take it home, restrip the wire properly, put the clamps on, plug it in and fire it up.Works perfectly and it still has the Lincoln 3 year warranty to boot!Doesn't quite match my Lincoln 175 (without gun) for $35 brand new, but it definitely was a steal.
Reply:Good find, nice story/description about it,and in fine web tradition, you suck.  New machine at 1/3 the cost of 'regular', yeah that's a decent find.  The best laid schemes ... Gang oft agley ...
Reply:Have fun with it.  Make some $ with that inexpensive machine!It will weld heavier stuff than your Lincoln 175.  David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Some Guys Have Allllll The Luck enjoy
Reply:GEE!!!!! Wish I could find a deal like that on a plasma cutter.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:jh I wouldn't buy any lotto tickets for a while, you've used up all your luck for a few days with that buy.  Good deal.  I love running across buys like that.Bob from Idaho
Reply:Good Grief!Great find!Miller 140 w A/SHF Flux Core WelderDewalt Chop SawSmith O/A TorchHarley Electra Glide Classic
GMT+8, 2026-1-1 01:54 , Processed in 0.108349 second(s), 18 queries .
