Lincoln Ranger problem
发表于 2021-8-31 22:26:33 | 显示全部楼层 |阅读模式
Hi all.  Just registered but been lurking for quite some time.  I have a Lincoln,  actually a Red-D-Arc GX300,  and it quit welding on me today.  Has no arc what-so-ever.  Machine has been running great.  It has 675 hrs on it and is in great shape.    Anyway,  today the engine had idled down to low speed and I went to scratch start it to let it rev up and the rod stuck when I hit it.  The engine grunted for a second and I swear I heard what sounded like a squeak right in the front of the machine,  like a belt squeal.  Then the welder lost all power.  Now it does nothing.   It won't even actuate the high idle.Seems like it should be something simple,  any ideas?
Reply:Forgot to mention that the generator part still works as it should.Thanks,  Ray
Reply:Have you made sure that all the switches are settled into there exact position.  Not sure about the noises, but my GXT will do that something when I switch ranges or polarity, and the switch doesn't flip all the way into position.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Yeah,  I went through and flipped through all the ranges and tried it.  Played with the controls some and still nothing.
Reply:Hmmm, the manual says for no weld output:- make sure you have good conections on the cabling, especially the work/'ground' lead;- make sure switches are set properly, especially the "Weld Terminals" switch should be in the "Weld Terminals ON" position when not using a control cable;- bad PC board or weld alternator, which means you go to a "Lincoln authorized Field Service Facility".  The best laid schemes ... Gang oft agley ...
Reply:I took the sheet metal off and went over it checking for loose wires.  All seem to be tight,  I wiggled everything with the amperage down down with the leads jumped.  It never kicked the high idle in.   I cleaned the brushes and they look good.I'm hoping a tech or someone that knows a bit about these things may chime in with some diagnostic checks.  I looked all the net for a service manual but couldn't find any.  I was a mechanic before I was a welder,  I'm pretty sure I can fix it if I can find some direction on it.Thanks,  Ray
Reply:WooHoo!!  It's welding again!!!  Problem wasn't with the welder at all,  it was a burnt lead.  Feel silly for missing it in the first place but I'm glad it's fixed.
Reply:I'm still curious about the noise you heard; any chance it occurs occasionally but you don't normally notice it? I originally was thinking about a short 'overloading' the generator/alternator and putting a large load on the belt, causing it to slip.
Reply:I'm thinking the noise was from the lead finishing burning,  like a bad connection.  These leads are pretty old and they came off my 400.  They've been gouged with plenty and that's what actually burned them up.   I loaded the welder in the same way and I don't hear the squeal anymore.
Reply:Glad you got it working.  I was gonna mention that sometimes I will forget to switch it back to "Local", and it will do the same thing.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:I have a GX271 I got out of Baton Rouge. You can download the manual from Lincoln using the K-code from your machine. You will need the code as there are 3 different manuals for the GX300.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:"It is a pro-Obama advocacy deed that every day attacks the McCain safari, attacks Senator McCain, attacks Someone Palin, and excuses wow gold Senator Obama.Do try something new. Americans don't want for ideology doctrines. Liberals transferral surmount without them.
Reply:whoops wrong postEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2026-1-1 03:51 , Processed in 0.096718 second(s), 18 queries .
