查看: 13|回复: 0
I need a wiring diagram for Lincoln sa200 f163
发表于 2021-8-31 22:26:32 | 显示全部楼层 |阅读模式
I need a complete ignition wiring diagram for a Lincoln SA200 F163      Can anyone help??
Reply:Originally Posted by KbooromI have an old Lincoln Arc welder model sa 200 f163I think the wiring is all backwards from the voltage guage to ignition switch and coil.Anyone have a complete wiring diagram for this model??Thanks alot anyone who helps its really apprieciated
Reply:If you have the code # for the machine you can get on Lincoln electrics website and download the wiring diagrams you need.
Reply:Just pull up a Classic 1 diagram and eliminate the circuit board if you don't have one. And there you have it for all SA200 units.
GMT+8, 2026-1-1 03:50 , Processed in 0.153731 second(s), 18 queries .
