Can I run the LN-25 from and Idealarc 250 I just picked up. If so what would be a good setting for .068 211 MP. Thanks. I know I would have to use CC as the Idealarc is only CC."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251 Syncrowave 300 30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200 1 short hood SA250 SAM 400
Reply:yes you can run it off the machine.Last edited by Scott Young; 11-28-2008 at 11:45 PM.
Reply:It will "workk", but not well. NR211-MP is a good wire to use. It will suck on thin stuff, but may work OK on bigger stuff. Can't beat LN-25 on CV.DavidReal world weldin. When I grow up I want to be a tig weldor.
Reply:Only wire you can run weld on any CC only machine is dual shield wire, and yes it will suck on thin material for sure. Mild steel will work though it'll be spray, or globular transfer for non structural, non critical applications only |
