Finally finished
发表于 2021-8-31 22:26:30 | 显示全部楼层 |阅读模式
Already got one customer!Last edited by kguit34; 07-24-2014 at 12:48 PM.
Reply:That's neat just needs a fold down cover so you don't get fined if you take it to a dump like here in KaliforniaYeah if you have an uncovered load in cal they fine you right there at the dumpBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Very cool idea.  Yours?  Patented?I take it you just tilt it up toward the back to dump/empty it?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yes thats correct!..I will build doors on the next one...this was a working pro to type
Reply:yes i patented it..
Reply:So how does it get dumped?  Where I dump occasionally at a transfer station, stuff has to be tossed over a barrier and into containers that are located on a lower level. Originally Posted by kguit34yes i patented it..
Reply:Originally Posted by OldendumHow can you patent a garbage can on wheels?  I've been driving one for years.
Reply:Brilliant!  Consider a bear proof model too!(you will get fined here in Utah without a cover as well)Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
GMT+8, 2026-1-1 02:13 , Processed in 0.098736 second(s), 18 queries .
