Demmeler Table
发表于 2021-8-31 22:26:30 | 显示全部楼层 |阅读模式
the pictures is Demmeler Table. Attached Images
Reply:Demmeler  Table Attached Images
Reply:awesome layout tables with hold down beams cast into the floor.i.u.o.e. # 15queens, ny and sunny fla
Reply:Amazing tables and setup. I bet those cost a little more then the new harbor freight fold up ones. You could buy 100,000 HF oes for what one of those cost.
Reply:Very impressive set up.  Must be big $$.Also the cleanest shop I have seen in a while.Paul
Reply:Originally Posted by Mick120I reckon that's a bit more than 'just a shop'......
Reply:Originally Posted by docwelderawesome layout tables with hold down beams cast into the floor.
Reply:lol, ok...?The floor might have been 'cast' around the beams, or more likely they could just be bolted in place so an existing factory doesn't require a whole new concrete floor just to use demeller stuff. You can see small holes on each side of the locating holes, they could be bolt holes.Last edited by MikeGyver; 07-22-2014 at 10:24 PM.Welding/Fab Pics: www.UtahWeld.com
Reply:one table about 20,000 $.
Reply:yes, It must be level.
Reply:Originally Posted by MikeGyverPretty sure the beams in the floor were not molten and cast into the concrete
Reply:Must be nice to work at a place like that with top notch equipment!"All of this and some of that's the only way to skin the cat!"
Reply:On an industrial level no one blinks at cutting out concrete, digging as deep as needed for a solid mount, and calling for concrete. Hours later you're in business.
Reply:What are these "concrete silos" used for?  Are these the spinning tanks atop concrete trucks?edit// Nevermind, found your other thread.  Definitely not going on top of a truck! Very cool table setup you have.  Thanks for sharing.  Business must be good!
Reply:Where in China are these fab shops with so many "western" workers?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I couldn't stand working there.....too clean for me.
GMT+8, 2026-1-1 02:12 , Processed in 0.141199 second(s), 18 queries .
