Guy bought this trailer and was told it won't scale correctly. Solution cut the tongue back and put front of tub about on top of 5th wheel. Trailer is a tri axle. The frame that was the tongue has seen better days so wether we did this or not it needed some attention. This fella does excavating so I assumed this would see daily duty hauling dirt/gravel whatever. Not that it won't haul this stuff but he plans to only use it for moving corn/beans from field to silo. Tub has also seen better days and he knows it wouldn't handle the abuse he can give it with dirt work. Anyway heres some pictures. I only lack 2 gussets for the kingpin replumb/rewire and shorten hydrauilic line for dump, and reinstall jack legs. Although he is considering just a single drop leg in the center of frame and then use air ride to raise lower to unhitch. Attached Images
Reply:Three more pictures
Reply:The bottom 2 rails will get bent upwards to act as guides up frame if need be.
Reply:Looks nice so far. Can't wait to see more.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller 625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita Baileigh NRA Life Member
