TIG torch WP-26F back cup issue
发表于 2021-8-31 22:26:27 | 显示全部楼层 |阅读模式
I am looking for WP-26F torch,I saw there are two type, one has back cup and the other has not.What is the back cup used for? gas leak or insulator.thank you!
Reply:No difference at all. It is just the way the different manufacturers get the job done. The 26 series uses the same backcap as the 17 series. The backcaps all use o-rings to seal the gas from leaking through and the main purpose is to lock the tungsten electrode in place.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Hi shovelonYou are right, I also think O-ring can steal the gas,  Sorry I didn't say it clearly.I want to know the red circle area. May I call it back insulator? what is it working for?The same WP-26F but difference design.Last edited by Dry Super; 10-12-2015 at 02:59 AM.
Reply:Just depends on who makes it.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
GMT+8, 2026-1-1 02:13 , Processed in 0.093502 second(s), 18 queries .
