Miller CP-302 question
发表于 2021-8-31 22:26:22 | 显示全部楼层 |阅读模式
Any one know if this is a machine where you can not only select voltages (3 phase) but also has a 1 phase or 3 phase switchable link in it?There is one at work that the control contactor failed in, they are going to scrap it.
Reply:I found the Manual on the Miller web site, no luck!May try to get it anyways.
Reply:the 302 does not have a contactor. only two ice cube relays and three scrs.One relay is controlled by the feeder. the relay tells the SCR firing pcb to turn on the SCRs full. The relays have a bad habit of breaking a small wire inside where it connects to the swing arm. easy fix.And yes three phase transformer welder only.
GMT+8, 2026-1-1 02:13 , Processed in 0.296339 second(s), 18 queries .
