Estate sale find
发表于 2021-8-31 22:26:15 | 显示全部楼层 |阅读模式
Table is 36" tall and 56" diameter 1.5" thick with about .020 off of being totally flat. I plan on drilling and tapping a few spots for hold downs on the top. The 8" Sioux grinder looks well used but starts and runs so quiet and smooth you can set a dime on it and it won't move. The shields for the grinder are still wrapped in the plastic they came in. I will make a couple end covers for it. The vise is a Paramo no. 6 made in England (never heard of it) and is in real good shape mechanically with the exception of one slightly loose pad. I don't know why the owner welded the swivel base to the table but that will change. I'll mount it on a receiver hitch. The stand is for the grinder and is 1/2" thick mount and base 36" tall. i'm debating on building a 4 leg base for the top but probably won't since it works fine on 3 legs. The price for all of it was $350. I think i did ok on the deal. Now i just have to figure out where the heck i'm going to put it in the shop. Space is becoming a scarce commodity. Attached ImagesLast edited by jbmprods; 10-17-2011 at 12:50 PM.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
GMT+8, 2026-1-1 05:38 , Processed in 0.101238 second(s), 18 queries .
