Need help sourcing 2-post lift positioner
发表于 2021-8-31 22:26:14 | 显示全部楼层 |阅读模式
I have been to the far reaches of the net and only found one company that makes what I'm looking for.  My employer mandates a minimum of two quotes.  Essentially what I need to do is lift a variety of table-like structures of different widths and lengths, up to 3 tons in weight, and then roll it over for easy welding.  ALM Corp. is the only company I've found so far that makes what I'm looking for, but their quote is nearly $50K.Does anyone here know of an alternate source for something like this?
Reply:I never noticed the manufacturer, but I have seen several different ones at DuPont and Toyota Plants.Google brought up...http://www.unidex-inc.com/~They have 1 & 2 Column Positionerand http://www.koike.com/index.aspxMaybe call them and see if either can accommodate you.Good luck.Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:That Unidex link looks like exactly what I was looking for.  I have a call in now for a quote.  Thanks!!
Reply:No problem, glad to help and good luck Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
GMT+8, 2026-1-1 08:48 , Processed in 0.268006 second(s), 18 queries .
