another Disassembly question
发表于 2021-8-31 22:26:13 | 显示全部楼层 |阅读模式
could someone tell me how to take this live center apart, the bearing is completly froze up. I assume the small set screw on the side of the collor has to come out, and there is a 3/8" plug like screw in the end of the #3 MT. I took that out and appears to be a hollow shaft, HMMMMMMMM?????  I can not find a brand name on the LC... Attached Images
Reply:Throw it out and get a new one..Trust me on this..It will NEVER be any good for anything after it gets seized up....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Put a greese fitting in the 3/8 thread part and greese gun it out.  Mac
Reply:no luck with the zerk....how does the big schroud come off? unscrew or pressed on?
Reply:It's now a dead center "The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Originally Posted by noriteIt's now a dead center
Reply:Yea, and i may have to burry it........
GMT+8, 2026-1-1 05:36 , Processed in 0.073828 second(s), 18 queries .
