sa 200 alt upgrade
发表于 2021-8-31 22:26:13 | 显示全部楼层 |阅读模式
Hello there I have a 1980 sa 200 and would like to replace my factory external regulated alternator with an internal regulated delco remy 130 amp alternator can someone tell show me how to wire it correctly??? . I will try to get pics on later!!
Reply:Howdy Mr welder,Hope this helps:http://weldingweb.com/vbb/showthread.php...011#post215011Good Luck
Reply:I just pop one in, out of a gm truck with a v groove, other than the belt , no mods are required
Reply:here are pics of what I have and the alternator I want to install and wire up! Attached Images
Reply:Mr welder!That's a serious alternator. Electrically you can wire it up the same was as the link in this post describes:http://weldingweb.com/vbb/showthread.php...011#post215011But it probably has a two-ear mount, and to produce max current will probably need more belt drive than the SA-200 has.Why the big alternator?Good Luck
Reply:yes its a 2ear on the bottom mount. they were free!!! I want to run an inverter for 120 ac power what do you think???
Reply:They were free! Sounds like you're shopping at the right place. I think it'd work. Not sure how compact the mount will be; and at max output, I believe there would be drive belt issues.How many watts of AC are you after?Good Luck
Reply:enough to run say a dewalt porta band .I think I will try to do sum tradin to a smaller alternator you are probably right bout drive belt issues didnt think about that thanks
Reply:The alternator and battery you have now would keep up for intermittent use.Or is the Motorola not charging?
Reply:heres a pic of my 1980 sweetheart ive had since 1994 she didnt always look this good she has bout 1500hrs on new engine . but when I took her apart she got murphy gauges and new hourmeter, paint, brushes radiator,rheostat, stainless exhaust and a chrome flapper! Attached Images
Reply:Okay this is a stupid question... but... what is the THERE HERE switch for?  Some sort of teleportation device when you wish you were on vacation in Haiwaii?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:yes it works fine I am just doing some upgrades like air filter any thing i can shes not being worked right now!!!
Reply:its for my remote rheostat..............get it?
Reply:Got a pic of the remote?  I would like to see what you got on it.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:no switch on remote. I made my own ditch box out of an old electrical box and the old faceplate off my machine and a new rheostat .
Reply:dont have pic of remote right now
Reply:hello there again here is pic of my remote and better pic of my baby Attached Images
Reply:And a pretty baby she is!Great job on the remote - and I too got a chuckle out of the 'Here / There' selector identification.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 05:36 , Processed in 0.075367 second(s), 18 queries .
