Lincoln 180- Question ??
发表于 2021-8-31 22:26:12 | 显示全部楼层 |阅读模式
Hi Guys; My question is , what is a Lincoln 180-T mig welder?               Is it short currcit or spray transfer Welder ?? ... Norm:
Reply:With solid wire and shielding gas the Lincoln 180T is a short circuit transfer unit.
Reply:Originally Posted by DanWith solid wire and shielding gas the Lincoln 180T is a short circuit transfer unit.
Reply:I think lincoln makes a kit for that unit, as does profax to run a spoolgun with that unit, however, it would be much simpler to run a teflon liner and use the same whip. Lots of guys do it.
Reply:Originally Posted by CruizerI think lincoln makes a kit for that unit, as does profax to run a spoolgun with that unit, however, it would be much simpler to run a teflon liner and use the same whip. Lots of guys do it.
GMT+8, 2026-1-1 08:57 , Processed in 0.166709 second(s), 18 queries .
