What's the difference?
发表于 2021-8-31 22:26:11 | 显示全部楼层 |阅读模式
I just bought a new lincoln pro mig 180 from lowes last night. I saw what looked like the same machine at home depot, but it was called a weld pak 180. The pro mig was $40 cheaper,so thats the one I bought, is there any difference (better or worse)  Thanks for any comments
Reply:I also bought the pro mig from Lowes the only difference is the name so they dont have to match the price
Reply:That's what I understood also.BTW Welcome to the forum Jerry. Glad to have you with us. Question: Why does someone with the name Miller own a Lincoln?  Just kidding, makes you think doesn't it.
Reply:What would the pro mig be equivelant to the 180T or C or neither ? I'm leaning towards the 180C but best I have found is About 780$ from IOC.Lincoln Ranger 8Lincoln 140c MigLincoln Tombstone(doesn't everybody have one ?)Miller 200Diesel/Heavy Equipment MechanicLead Plant Mechanic Municipal Water
Reply:The Lowes and HomeDepot Lincoln welders are typically the "T" models, ie the tapped machines and not the "C" continous-voltage-control models.  YMMV.Pretty much the same machines, different label/name.  The best laid schemes ... Gang oft agley ...
Reply:I know this is an old thread... but I did read several of these threads before I purchased mine and just wanted to throw in an update.I got the Pro-Mig 180 and thought I would be getting a dual tapped machine.  But the power is tapped and the feed is variable so I am very happy about that.  Maybe they changed something between when these post were made and I purchased mine.Thanks.Jamie WebbWelder & InspectorBusiness and HobbyLincoln Pro-Mig 180 with Spool Gun and Lincoln AC225
Reply:Originally Posted by Jamie WebbI know this is an old thread... but I did read several of these threads before I purchased mine and just wanted to throw in an update.I got the Pro-Mig 180 and thought I would be getting a dual tapped machine.  But the power is tapped and the feed is variable so I am very happy about that.  Maybe they changed something between when these post were made and I purchased mine.Thanks.
Reply:Except the Hobart Handler 125EZ...
Reply:Originally Posted by MAC702Except the Hobart Handler 125EZ...
GMT+8, 2026-1-1 05:38 , Processed in 0.074185 second(s), 18 queries .
