Lincoln SP 125 plus
发表于 2021-8-31 22:26:10 | 显示全部楼层 |阅读模式
Would the Lincoln Mig 140 be the closest unit to the older Lincoln Mig SP 125 plus???Thanks, Mike
Reply:The 140 C would be the match. Really, the 125 is a bulletproof little unit. The 140C should be the same, although it does weld a bit nicer overall.
GMT+8, 2026-1-1 05:38 , Processed in 0.073161 second(s), 18 queries .
