Golf cart trailer
发表于 2021-8-31 22:26:07 | 显示全部楼层 |阅读模式
Hello everybody, pics of a golf cart trailer I built. It is nine foot long but should rather be ten with the extra foot in front of the axle.
Reply:Very nice. I like the idea of the shocks to control the tilt of the deck. Do you need all four ?
Reply:Any pics hooked to tow rig and deck tilted open?Qualified & experienced at welding scrap metal
Reply:Re: Gofl cart trailerVery nice. I like the idea of the shocks to control the tilt of the deck. Do you need all four ? I tried 2 but 4 works betterRe: Gofl cart trailerAny pics hooked to tow rig and deck tilted open?I will post some next week.
Reply:You do some really nice work!GravelThe difference between theory and practice is that in theory there is no difference.
Reply:I can't see for sure, but it looks like the front and rear spring mounts are fixed. If so, how can the spring flex?
Reply:Re: Gofl cart trailerYou do some really nice work!Gravel Tx Gravel!Re: Gofl cart trailerI can't see for sure, but it looks like the front and rear spring mounts are fixed. If so, how can the spring flex?The front is fixed with a bolt and the rear is on a slipper bracket. Actually not so nice a lot of play and wear and tear. We're on holiday for 5 days I'll post a pic on the weekend.
Reply:Great looking trailer. Looking forward to seeing more photos when you are back from holiday
Reply:Fine build! Great looking cart trailer.Old tools, trajan band saw, grizzly, delta,lincoln
Reply:Re: Golf cart trailerFine build! Great looking cart trailer.Tx!
Reply:Hallo everybody, the pics as promised!
Reply:Great looking cart trailer.   What part of South Africa are you located.    I have been to Limpopo back in 07
Reply:Originally Posted by richeyGreat looking cart trailer.   What part of South Africa are you located.    I have been to Limpopo back in 07
GMT+8, 2026-1-1 05:37 , Processed in 0.100857 second(s), 18 queries .
