Between the two, which would you take and why? This is home shop welding, 70% stick/30% MIG.http://www.weldingsuppliesfromioc.co...welder-k3963-1http://www.weldingsuppliesfromioc.co...r-pkg-w1004201-RuarkLincoln 3200HDHobart Stickmate LX235TWECO Fabricator 211i
Reply:They both weld great.Very similar capabilities.The only differences I note is that the 211i is much bigger, heavier, and bulkier. No carry handle either.The 210mp is much smaller, about 20lbs less weight. Also note that the 210mp will only take up to a 8" 12lb spool. The 211i will hold a 44lb 12" spool.I own the 211i, and have used the 210mp quite a bit.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Originally Posted by AKweldshopThe 210mp is much smaller, about 20lbs less weight.
Reply:The 211i is the old Thermal Dynamics....I've used them, I wouldn't own one, biggest problem was the drive feed had inconsistencies I tested a new Power Mig 210....two thumbs up thereyou have to ask yourself, why such a big discount? My lws can't hardly keep a PM 210 in stock, no discountLast edited by Randall_H; 10-18-2015 at 12:16 PM.
Reply:The 211i feeds wire just fine.. I use a Lincoln 15 ft magnum gun 200 gun,and 33 pound spools.. and a fixed Tweco 12 ft one.. The 211i has more top end voltage power.. Put some 90-10 gas in and find out..If it had a feeding problem, it would show up on the spray-arc wfs.. I have owned many feeders over the years, and know if something has any feeding issues.. The Wire-feed motor feeder is much bigger, and stronger on the Tweco. Just uses the single driven drive roll style, and not the two driven of the Lincoln..Setup correctly the 211i is totally fine for the job. If you use the stock Fusion gun, you will never know how good the 211i is. (IMO) The range of the inductance control is a much bigger feature then a ten step up/down setting on the Lincoln. They should of put .1 adjustment in like their quality machines have.. put in every other adjustment. in that machine Variable inductance knob for fine tuning your arc exactly the way you want it in the Tweco.Might want to hang on a bit, and check out the new Esab machine..Last edited by Brand X; 10-18-2015 at 12:50 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i |
