Newb Questions
发表于 2021-8-31 22:26:05 | 显示全部楼层 |阅读模式
Hey everyone.Doug from Calgary albertaRecently picked up a very gently used hobart 210mvp for $600 cdn.Thats about 65 cents USDAnyway complete newb to welding and i have some complete newb questions.Contact Tips- are these things brand specific? ie do i need hobart tips or can i get away with Lincoln or Miller ones?Gas - looking at picking up at bottle of 75/25- any particular size bottle i should look at?Wire - any particular brand stand out as better than the others - mostly interested in solid wire for now - unit came with a 10lb roll of fluxSpool gun - i will be looking to learn aluminium welding at some pointAre spool guns brand specific. Will a lincoln or miller work on this hobart?And....last but not leastWhat size wire should one start out learning with?Thanks
Reply:Tips are brand specific- You might be able to use a generic brand but even the generic brands are specific to Lincoln,Miller, Hobart etc.Spool gun is brand specific AND model specific..030 solid wire is a really good fit for the HH210's range.I haven't run enough wire to make a judgement on a brand. I just grab the wire off the shelf at my LWS- I don't even know what it is Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Any is good to start with, then when you think you know  what you are doing, switch to another and notice any differences. But stick with one until you are quite comfortable with it.+1 on Ed's post.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by Titan99... Gas - looking at picking up at bottle of 75/25- any particular size bottle i should look at? ...
Reply:Locally to me, little bottles cost a lot to fill, and you need to fill them often. For me, a 300 CF bottle is a lease thing, but the cost per CF is low enough to break even. I do own some little tanks for portability, or when I run out on Sunday.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:Hobart or Miller tips  work on the factory supplied gun.Lincoln's .030 L-56 performs very well on this unit.ESAB Migmaster 250 Hobart Ironman 230Multimatic 215TWECO Fabricator 181i & 211iHH125EZ - nice little fluxcore only unitMaxstar 150 STH - very nice
Reply:Originally Posted by OldendumBigger is better unless you have trouble with handling the weight.  I would want at least an 80 cubic foot or a 125 CF.
Reply:Well here are my very 1st welds1/4 steelArgon/co2 mix at 18hardest thing I found was keeping a consistent stick out
Reply:Watch some of Jody's videos at welding tips and tricks.   Pay attention to how he does a dry run on his welds sometimes a few times before welding.   Then duplicate that.   Watch your stickout distance on those dry runs.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Hi Doug. Welcome from BC.  These guys have already given you some great advice. Wish they were around when I was a newb.:
Reply:100% great adviceThink i need practice most of all
GMT+8, 2026-1-1 07:24 , Processed in 0.102182 second(s), 18 queries .
